I’m in need to change the spindle bearing on the Tum 35. I’m thinking someone has changed this bearing previously. The spare parts catalog calls for a NN3013k-P51 the bad one currently in my lathe is a NN3013 AS.SP.
I can’t seem to locate NN3013k-P51 bearing any where. I don’t know much about the bearing suffixes, I believe P51 is tolerance and radial clearance
Does anyone have any knowledge on what would be a suitable cross reference bearing that would work for this tum 35 lathe?
And had anyone changed the spindle bearing on a tum 35 that has any helpful information or literature to make the job go smooth?
