Never seen brakes like these, but I like them. The brakes are geared to spin 50 times faster than the wheels. A band brakes actuates from the pedals and slows down the outer drum. The drum is two piece held together with two springs. Between the pieces are large ball bearings sitting in ramps. So when the outer drum slows down from the band, the drum expands width wise and rubs against two wear plates. It's a band and reverse disk brake at the same time.
Case 430 brake job
Originally posted by wierdscience View PostBrakes on tractors are more of a suggestion really....Keith
__________________________
- Likes 3
Originally posted by LKeithR View Post
Not if properly maintained--80 per cent of the problems with farm equipment are owner created...
On IHC tractors they are under a side cover.
Not bad really.
-D
Replaced both fuel filters and hydraulic filter, engine filter and oil was changed. Should probably drain the coolant and put fresh in it. Still working on the brakes, as in waiting for parts to come. Have to make or fix the throttle rod. This sucks not having my machine shop here
Originally posted by RB211 View PostNever seen brakes like these, but I like them. The brakes are geared to spin 50 times faster than the wheels.
