A big part of my reel building requires vibratory finishing machines, synthetic cones and then treated cob. I find these machines fascinating and could watch them all day lol. I built the machine with the treated cob and saved thousands doing so. Currently working on a few reels....
Vib finishing,anyone else here do it?
Originally posted by RSG View PostA big part of my reel building requires vibratory finishing machines, synthetic cones and then treated cob. I find these machines fascinating and could watch them all day lol. I built the machine with the treated cob and saved thousands doing so. Currently working on a few reels....
Originally posted by JRouche View Post
I do the synthetic tetrahedron with dish soap
How do you like them and how long does a cycle take to cut the edge and smooth the face?
Ontario, Canada
Originally posted by Toolguy View PostI use ceramic pyramids in a cement mixer with poly tub and paddles.
Ontario, Canada
I do steel or aluminum (not together) as needed. It 's more of a rolling motion, so they don't bang together much. There's a good amount of water to smooth out the action, and Dawn and water keeps the media from loading up with metal particles.Kansas City area
- Likes 1
And what do you primarily finish, steel or aluminium components? I only use mine for aluminium parts and a big finishing company near me recommended using synthetic cones way back so that's all I've ever used but from what I've read Tetrahedron media can get into tight spots and puts a very fine finish on the parts suitable for anodising as well.
Never used vibratory finishing. I do tumble parts sometimes, with varying types of media.
What would you say is the biggest difference, aside from the potential of impact damage from tumbling?
I have wanted the parts deburred or sharp edges removed, and have found that tumbling really does not do that very well. Does vibratory finishing do a better job of deburring and blunting sharp edges?CNC machines only go through the motions.
Originally posted by J Tiers View PostWhat would you say is the biggest difference, aside from the potential of impact damage from tumbling?
Ontario, Canada
Yes, the vibratory finishing does a better (faster) job than tumbling. The media is sitting there rapidly rubbing back and forth over everything. The more media (weight) you have in the container, the better it works. You can only fill up a given size of bin to a certain level for optimal media action, so to have more weight, you would have to upsize to a larger unit.
The rotary tumbler does a passable job, but you have to run the parts longer. Most of the vibratory finishing I've had done didn't leave the parts in as long as I wanted them to. I get the results I want in the cement mixer. The run time really doesn't matter, because you can be doing something else the whole time.Kansas City area
Wow 12 hours? My parts would be ruined if I let my machine run that long. What size is your finisher?
- Likes 1
Thanks. It does take a very long time in the tumbler, and 12 hours is not unknown at all.CNC machines only go through the motions.
