Originally posted by Doozer
View Post
Drill bits have run out anyway so I have not lost anything it it has a little. So far I'm very satisfied for the result and have not needed it for any work
that requires getting between + - .001. As for tapping, the tap follows the hole.
Obviously, I had to cut the threads in the cap with a single point and not hit the end and break things. That was fun.
I think I had to turn the chuck the last little bit by hand.
The truth of it is, when I can use a die in the tail stock, I use it!
