Small Jet saw I've had for years was working fine until I installed a hydraulic down feed unit.
Now the blade binds in the cut and jumps off the wheels.
I'm running at 200 sfpm with a 14 tpi blade.
Yesterday was cutting 1.5" round bar 6061 with a very slow feed
thinking 14 tpi is too fine to clear the dust.
It repeatedly got into the kerf about .375" and that was it.
I turned the material in the vise, set the blade back down and it finished the cut no problem.
I don't have enough material around to conduct a lot of experiments so has anyone had this happen?
Again, no problem before installing the down feed unit.
