I did a lot of woodworking at home before I finally bought the machines to be able to do metalworking at home. That taught me to be sensitive to the inhomogeneities in the wood stock I had.
Recently I have been working on some annealed 4140 drops from the ends of a 4.5" round bar. Over the last few days I have bored the center out, flattened one side to give a 2" wide flat, drilled 18 tap holes and tapped it with 7/16-14 threads to 1.5" deep.
While drilling the tap holes I noted that the behavior of the drill was not the same all the time. While drilling some of the holes the sound made by the drilling operation would sometimes suddenly change. This was often accompanied by a change in the nature of the chip. After 1/2" the sound would generally return to the original sound. The sound, resistance to hand feed, and the nature of the chip seemed to indicate a small region of different hardness.
Is that a reasonable explanation? Does raw steel stock occasionally have inhomogeneities like that? Or am I just missing something that I'm doing that changes the progress of the drilling operation slightly?
