I've been following amateur watchmakers on Youtube. A thought occurred to me. A watchmaker was working on, I think, a lady's Seiko watch. The case was less than 7/8" wide. The face was held on by two screws that bit on two posts welded to the back of the face. To the naked eye of a 74 year old, these screws are INVISIBLE.!.! Under the microscope, the head is a perfect cylinder. The slot is perfectly centered, squared, and even. The head has a mirror finish. The threads are PERFECT, and continue to the head. They were obviously ground, not cut. The head of the screw (I'm guessing) was less than 1/64" in diameter.
The smallest screw I've made was to replace a rusted out screw holding the windage mechanism of a Lyman 57 rear sight. Though the original had some odd thread, I replaced with a 2-56. Using the tap and die for this was an experience. All came out well, and you can tell the difference, only if you disassemble.
Still, how do watch manufacturers DO this? Without a microscope, you can't even really SEE this screw. Work holding?
