I've been puzzling on this one for a bit and thought I'd pass it by the Brain Trust. My mom is losing her faculties slowly just in the last 2 years. Not Alzheimer's, just slow loss of memory and gets easily confused. But she had heard that her hearing aids might work with a TV somehow so she could watch if she couldn't sleep without disturbing her neighbors. I figured far better was an off the shelf Bluetooth headphone if I could swing a transmitter.
I have a fairly good headphone candidate. Unlike many, its very small, light and there's only one button. But the puzzle is setting up the transmitter in a way it's easy for her to switch between speakers and bluetooth. Most TVs cut off the speakers when something is plugged into the audio OUT jack, which is not the way to go. Imagine her trying to reach around the back of the TV on the wall every time!
Even buying a newer TV with bluetooth doesn't solve the problem, She'd never remember how to do this: " Press button on your remote control to select Settings > Display & Sound > Audio Output > Audio Output, and then select the Bluetooth option to listen to the audio through bluetooth devices." So much of our electronics required digging through menu after menu that is just beyond an advanced senior, I gotta simplify!
So my best plan is to split the audio OUT line to both the bluetooth transmitter and standalone amplified speakers like for a computer. All she would have to do for headphone use is switch off the speaker power and hold the button on the headphone till it says "power on", and then it will automatically pair with the transmitter that is always connected and powered. Any thoughts or better ideas? Thanks.
