Is it like vegetables? Good for you, so they don't want to use it? I'm greasing or putting anti seize on everything on the tractor so 20 years down the road I don't have to wage a battle on it. Seriously, why do people not use it?
Why do people not use anti-seize?
I use anti-seize for extreme conditions, usually high heat, like exhausts and spark plugs. I think an ample coating of motor oil or grease is sufficient for everything else metallic, except high-pressure oxygen fittings.Last edited by fiddle fixer; 08-16-2022, 07:59 PM.
Most people don't think 20 years in advance. When I work on machinery, I do think of the difficulty of the work and how to mitigate the bother for somebody else in the future. Things like taper pins can be fitted so that the small end is not only visible, but identifiable too. Parts that do not require a tight fit can be eased and lubricated so they can be dismantled in a fraction of the original time. Oil, grease or assembly compounds keep the joints and fasteners from corroding.
Does not take 20 years down the road can just take 1 or two out in the elements to warrant using it, wheel lugs are a good example being in constant water and salt and corrosion,
another honorable mention is spark plug threads - some of today's double iridium plugs can go up to 100,000 miles, and most people think "great" yeah till you go to remove them and pull part of the cylinder heads aluminum threads with it...
anti seize takes up the space that carbon normally would - carbon fills all the little area's between the threads and the plug, but with anti-seize the grease will leave but the solid lubricants will not - better to have that in there then the carbon,,,
Of course you have guys like Andy (VTP) afraid of the silver color and afraid of washing his hands or something...
I been using anti-seize for over 45 years, it's a must have and a must do on certain parts....
- Likes 1
I use it all the time. I must have 10 cans floating around in different places between the shed, the basement and the garage.
But we are all shop guys. Asking why "people" don't use it is another matter entirely. Most average folks don't use it because they don't have any technical knowledge. Basically, they don't know any better.
- Likes 2
...same reason I don't use toothpaste on everything.
Anti- seize is good for what it does, and I use it on things where
-they get stuck if I don't
-they won't come off if I use it
-the fastener goes into aluminum.
It's messy, but also, it derates both the attaching torque and the resistance of a
fastener to backing out. So for wheels that rust onto hubs, I use it all the time.
For driveline bolts that are torqued to 80% of plastic, AND have a history
of backing out, I never would. Because it'd both mess with the assembly
torque AND increase the chance that they'd loosen.
For tractor bits that sit outside? All the time.
trusting in Seattle
Originally posted by A.K. Boomer View PostDoes not take 20 years down the road can just take 1 or two out in the elements to warrant using it, wheel lugs are a good example being in constant water and salt and corrosion,
...........................................Originally posted by Tobias-B View Post.................................................. ..........
t
Last edited by J Tiers; 08-16-2022, 01:03 PM.CNC machines only go through the motions.
Originally posted by Tobias-B View Post...same reason I don't use toothpaste on everything.
t
and things like wheel lugs take common sense also ---- it can derate the proper torque application for them too, but so can dry chirping on the verge of galling or galling lugs and iv seen plenty of them also...
Used correctly it's great stuff and in fact I cannot imagine being a mechanic and never using it on anything - to me that's irresponsible ignorance...
- Likes 1
Gosh I mentioned it for wheel lugs a year or two back. What did I get? A long list of people telling me how bad and downright dangerous it is to do that......... "it's gonna kill you!"...... "the wheels are gonna fall off when the lugbolts break off because you used your full weight on the wrench and then jumped on it".......
t
rusting in Seattle
Originally posted by RB211 View PostIs it like vegetables? Good for you, so they don't want to use it? I'm greasing or putting anti seize on everything on the tractor so 20 years down the road I don't have to wage a battle on it. Seriously, why do people not use it?
Example. I was making up some links for the rear suspension of my car. The threaded inserts for the bar were mild steel and the rod ends were stainless steel. I was just mocking it up. So I threaded the rod end on and measured then was going to disassemble for welding. It was stuck, I tried everything except for heat. The 5/8" rod end was a loss. As was the weldable insert. I never forgot again.. JR
Rust is just one reason to use it to guard against --- just plain dry where im at is another,,, also SS fasteners don't stand a chance without it, a plethora of reasons why it will always be on my shelf ready to go...
My compound bow has adjustability between 30 - 70 lbs pull and my main adjusters go into the aluminum frame of the bow, those I do have slathered as the very long bolts are also my built in bow press that allows me to disassemble the bow to work on and iv had it down many times... just grease would suffice but anti-seize attracts less dirt and does the job better...
Well, it rains around here a LOT. And when I lived in Ontario for a few years they used beaucoup amounts of salt on the roads. So I've learned to use grease or NS on just about anything vehicle related that I worked on to save myself from future annoyance. This translated over to the bicycles that were used for year round commuting for both corrosion reasons PLUS many bicycle fasteners are threaded directly into aluminum parts. So grease or NS was almost a must to avoid galling and thread damage.
It's like the Frank's hot sauce commercial.... I use that *[email protected]& on EVERYTHING!
I've had some folks ask me if I'm not concerned about the screws backing off due to the oil, grease or NS. I can get the same tension on the fasteners with less torque and suffer from less thread wear and I've never had any of them lose any of their initial torque load.Chilliwack BC, Canada
- Likes 1
You guys talk about 'de-rating' the torque as though it was de-rating the 'tight'. The torque is lowered because you get the same tension on the fastener with less resistance. I have personally never had a properly torqued fastener, anti-seize or not, loosen by itself. Yes, I use it on lug-nuts and they're still hard to remove, just not impossible on the side of the road with OEM tools.Southwest Utah
- Likes 3
