I picked up a Mitutoyo 8" electronic caliper at a used goods store. Naturally, the battery (SR44 type) was dead. Of course, I didn't consider the possibility of leakage and corrosion. The battery compartment didn't look too bad, but I've been unable to get the thing to work.
Tried a paper napkin soaked in rubbing alcohol over a pencil eraser and used a drop of Corrosion-X on the battery. Also tried Red Cramolin. No joy.
Any ideas?
It came with what must be a low-end Starett mic; it has no friction or ratchet thimble, so the deal isn't a total loss.
Interestingly, I have a HF digital caliper, and the electronic part appears to be made by the same outfit.
Any ideas?
