The problem with modifying the motor is not the process (that's easy), but that you are dooming yourself to having to do that again when you replace the motor. Motor sizes go with certain shaft sizes.
Making a "special" once means that there is likely no other motor which you can find that will fit without modifying it. Now, next time you need to replace the motor (they do fail), you will not have a lathe (dead motor) and will need to modify the shaft or pulley again.
Using standard stuff whenever you can means less trouble in the long run.
