I know some people use new ones for tramming. I have used a large fly wheel from a truck as a base for a grinder stand. It seems like even a largish brake rotor is too light weight and not wide enough to be very effective for that. So, just more scrap, or good for anything?
Used brake rotors good for anything?
- Likes 3
Originally posted by fixerup View PostI have made a lazy susan for my 45 gal drum garden. Welded a skirt on the bottom edge and filled it with golf balls. Another simpler version was used for my patio umbrella. It was just a welded tube to a rotor driven in the ground and a second rotor attached to the umbrella
I use them on my squat rack - too cheap to buy disc's and too old of a meathead to use huge weight anyways so they suffice...
Some good ideas - I like the golf ball bearings!
Do you have a boat?"A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
I have a stack of 'em! A bunch are used for adding weight to the garden tractor in winter. A simple "post" goes on the hitch mount, and the brake discs are stacked on.
IIRC its a pile of 8 , so the weight is not trivial, Makes a huge difference when plowing snow.
Another use, a bit off the normal, is I use them for rough and ready lapping wheels. I have a precision "Lapmaster" from my optics days, and easily attach an old disc brake rotor to the machine with MAGNETS. It's just the thing for "flattening" most anything, using various grinding or polishing "grits". From "Black Beauty" sand blasting grit to fine clover polish, there is always something that needs a better finish. Planer knives, Plane blades, etc. Not for everyone, but something ;-)
Oh! and bases for support stands ;-)
