I didn't break my 2mm endmill!
Last edited by Black Forest; 01-10-2023, 12:20 PM.Location: The Black Forest in Germany
How to become a millionaire: Start out with 10 million and take up machining as a hobby!Tags: None
- Likes 2
Babying the feed rate was exactly the way to go, and 10000rpm if your machine will get that fast. Think of the difference of size between that 2mm and what you are familiar with and reduce the rates in that ratio, then take off some for the smaller cutting edge speed. I buy boxes of 20 little solid carbide cutters of 3mm down to 2mm from China, very cheap, then if one breaks, there are no tears, and our mills best speed is only 3000rpm.
Originally posted by gellfex View PostI didn't want to get hit in the face.
- Likes 2
Originally posted by Black Forest View Post
I leaned back in my chair when the belt started growing!I didn't want to get hit in the face.
I don't know what belt to use, a mini V kept rolling over. I'm sure I'm not alone in having shelves full of half done projects!
Regarding using tiny end mills, I ended up making a mount for my Foredom flex shaft tool holder (that's the Foredom Motor in the rig) that strapped onto the quill. Worked great to get into that 10k range.
Good job! And welcome to the club. Smaller can be a bigger challenge than larger.
I have a Unimat and it will do 2mm all day and be totally happy at it. I have used it for around 50 years and I can't remember breaking any small end mills. Anything above 1/4" or 6mm is a big cutter. Of course, it has the high spindle speeds, up to 10K, that make this easier.
As for the belts, the Unimat uses 1/4" O-ring style belts and they do belly out somewhat at the high speeds but they only rarely break. And when they do, there is little or no danger to the operator. They just flop down in place.Paul A.
Originally posted by RB211 View PostFirst time with my CNC mill, I must of snapped 10 carbide end millsLocation: The Black Forest in Germany
You are probably using 3/8th size and larger, I'm around 1/8th with the bench top CNC.
Originally posted by Paul Alciatore View PostAs for the belts, the Unimat uses 1/4" O-ring style belts and they do belly out somewhat at the high speeds but they only rarely break. And when they do, there is little or no danger to the operator. They just flop down in place.
I had to drill five .020" diameter through holes in a row in 3/4" thick copper. If any of the holes were bad the part was ruined.
Interesting customer, medical patient monitoring equipment and I went to engineering school with my customer contact. He was a wannabie machinist so he insisted on telling me how to do jobs and supplied the tooling. Fine with me. Using my smallest CNC mill I wanted to hold the drill in an ER25 collet. That size is not made so the guy had a couple custom made, must have been expensive.
We had problems with regular copper. He applied to the FDA to allow us to use tellurium copper which is slightly radioactive but machines much better.
Peck drilling in small increments with flood coolant with a slight pause as the drill re-tracked between pecks. The pause was enough time to use a fine brush to make sure no debris was left on the drill flutes when they pecked. The part was to pump "body fluid" through for cooling. In all the years I worked on medical equipment customers always said body fluid instead of blood.
