What is the model number of the jet lathe? The manuals for many of them are online. I have a Jet GHB1340 and the manual is online which includes the wiring diagram.
Jet Lathe
Each contactor has a manual over ride on the front, pushing this in closes the contacts operating the relay manually.
If the machine runs with the contacts closed there is a control problem, if it does not run it is a power problem.
This is a diagnostic tool.
- Likes 2
Originally posted by Bented View PostEach contactor has a manual over ride on the front, pushing this in closes the contacts operating the relay manually.
Retired - Journeyman Refrigeration Pipefitter - Master Electrician
Originally posted by wmgeorge View Post
As someone who has worked in the field since 1962, that is good way to A. Burn out a motor B. get burnt from the flash if there are shorted wires. If you zoom in on that contactor on the left it looks like something is burnt. If you don't own a meter then you should step back and let someone who does check the circuit.
if YOU say they are never to be used ? ? ?
-D
DZER
Then why the fuk do contactors have the ability to manually over-ride
-DLast edited by wmgeorge; 01-17-2023, 10:23 AM.Retired - Journeyman Refrigeration Pipefitter - Master Electrician
Back a ways, a VFD was mentioned. I have a Grizzly 12x24 and it had motor issues and I converted it to a 2HP 3 phase motor and VFD and used the existing control locations on the apron and headstock for FWD/OFF/REV and speed control. I run it in gear configuration C-6 (600 RPM at 60HZ) most of the time and use the speed control from the VFD. Also the quick reversing is nice for threading. IMHO, the only way to go!
PeterGrantham, New Hampshire
- Likes 1
Peter, I also have a Grizzly lathe, but 12 x 36. My single phase motor is fine, but I was thinking about converting many times. So you use apron lever for FWD/OFF/REV. What existing controls do you use on the headstock? Emergency stop? And you probably added the speed control potentiometer there.
600 RPM is my favorite speed on this machine as well. It is C-III in my case. Do you still experience gear "clunk" at startup and reversing? I do and it is bothering me. The only way I found to reduce it is to rotate the chuck manually in the opposite direction before start. If I would use a VFD for a slow start, this problem should go away.
Originally posted by Doozer View PostOff topic but...
Man those EU or ISO rated contactors are so much
smaller than the NEMA rated contactors. I can't see
getting the same service life out of them.
-Doozer
For power off testing of the contacts and aux switches, do as you wish have you ever seen a flash across a 3 phase contactor? They are also there for a visual indication of the contactor pulling in.
The owner of one of those printing plants did it once, he told me how he burned his hair and melted the frame of his glasses. After that he wouldn't change a light bulb !
Pushing in a contactor by hand under power is a really bad idea except for a very skilled electrician (few electricians are versed in motor controls). Measuring the coil voltage and then across the contacts is the safe way.
-Doozer
All that to avoid putting "needless resources" into constructing the contactor and/or applying it. They are not fans of over-design in the EU. Heck, they even figured out how to make the neutral the absolute smallest that was possible and still work. That's why there are such strict limits on line harmonics.
It's a design choice, and that's how they chose.CNC machines only go through the motions.
My presumption (maybe wrong) that the person pushing in the contactor
knows it's function or what it powers. On a lathe with criss cross wires
between 2 contactors, a pretty sure bet is that they are reversing contactors
and they control the main motor. Another presumption (again, possible
wrong) is the machine worked previously and is recently having a problem.
It is good advise not to just walk up to a previously unknown machine and
just start pushing in coils. All of my machines I have either made the control
panel from parts myself or am intimately familiar with from having worked on
them before. So I know what things do. But if I was at work, I would not be
randomly trying contactors without being absolutely sure what they do.
So right on with that.
-DDZER
- Likes 2
600 RPM is my favorite speed on this machine as well. It is C-III in my case. Do you still experience gear "clunk" at startup and reversing? I do and it is bothering me. The only way I found to reduce it is to rotate the chuck manually in the opposite direction before start. If I would use a VFD for a slow start, this problem should go away.Grantham, New Hampshire
- Likes 1
