Anyone recognize these AXA storage holders they are cast aluminum with a machined slot got them in an estate sale no info wondering how old
Mystery tool holder
Could this be used to hold tool holders for grinding the tool without removing it from it's holder? Wood screws suggest a wooden base further suggesting hand touch up work on the tool.???
DanK
reggie_obe makes a good point. I fell victim to the very thing I detest...not carefully comprehending what I thought I read. Being a creative person, I quickly saw other uses instead.
DanK
Originally posted by Tim Clarke View PostMy impression is that these were likely made by a home foundryman with some skills. I like them.Chilliwack BC, Canada
- Likes 2
The shape means that a collection of holders will take up a fair bit of room. And it needs room enough between multiple vertically spaced rows that the holders can be lifted up and off the dovetails.
I went with a slightly different option. Straight out off the holder and straight on. So the spacing can be fairly close. These dovetail "posts" were done with oak that I had on hand. But they could easily enough be done with metal, plastic or 3D printed as well. And the presentation puts the shape of the tools right handy to the eye.
I've since gotten enough more holders that the rack shown is almost full. There's only three spots left open now. And I've got a few shop made ideas for those positions.
If I was doing it again I would not bother with the full dovetail shape. I'd just do a simple bevel cut for this shape.
- Likes 1
I dunno ... the 2 SHCS's look like they are for locking the tool holder into this gizmo. I.e., like 2 tiny pistons. That doesn't make sense for being a storage holder. So, assuming that these screws are for fixing the holder, it looks to me more like a jig for grinding. One or two of its edges would run along a fence that controls the ground angles. The nub at the bottom to grasp it with.
EDIT: WAIT - brain fart. Those screws can't hold it - they're covered by it. Unless they are slotted on the back side, for a screwdriver to tighten. I need a pic of the backside.Last edited by Bob Engelhardt; 01-26-2023, 02:00 PM.
BCRider, I originally went with plastic dovetail bars screwed to a board, kinda like what you have. Was not really happy with that, so I replaced the board with one drilled on modular spacing for 1/4" pins spaced apart to snug the tool holder nicely. The pins can be moved around by hand (think cribbage board) for quick adjustments. Now Mikey likes it! LOL.
DanKDanK
