Always wondered what the ends of a transoceanic cable looked like—large telephone booth or huge silver building? 3 tubes of fiber optics Grover Beach to Singapore, HongKong and Tokyo. 1,500 miles total. Tubes drilled 600 ft. of length under surf line, cables will be pulled via ocean floor tractor, burying 4 ft. below.
Local calls 5 cents.
Originally posted by The Artful Bodger View Post
15 thousand miles would be shorter to go the other direction, I assume it is 3 cable each of 5000 +/- miles?
But I was replying to the 15 HUNDRED miles in the OP. 15 hundred can't be - must be 15 thousand.
Oop - reply collision
