Removing a drill chuck arbor
Hard (for me at least) to tell what's arbor and what's chuck. But it looks like there's a groove for using those slotted wedges that are made for pressing arbors out. They're made specific to the JT in question.
Otherwise you may have to "make" that hole in the back. It's doable ...I once did, and therefore anybody can do it.Last edited by lynnl; 02-02-2023, 08:23 AM.Lynn (Huntsville, AL)
- Likes 1
I have never done this in a keyless chuck, but did a couple of keyed ones. Opened the jaws and drilled the hole through the center of the chuck. Then used a pin to press the arbor out.
I know keyless chucks are different, but I don't think there is anything in the center of the chuck. Am I wrong?
- Likes 1
Originally posted by Doozer View PostTake the hood off, take out the leadscrew,
and there is a hole in there.
Use a pin and press the arbor out.
-D
Usually I have to grind wrench flats on the body using the surface
grinder in order to grip it. You got a gift right there and don't even
realize it.
-DoozerDZER
- Likes 1
It looks like Doozer was right - you have to take the chuck apart to remove the arbor. Here is an instruction for a similar chuck disassembly. https://www.machinistblog.com/rebuil...t-drill-chuck/
Do not drill the hole through the chuck center - it will destroy it.
Originally posted by mikey553 View PostIt looks like Doozer was right - you have to take the chuck apart to remove the arbor. Here is an instruction for a similar chuck disassembly. https://www.machinistblog.com/rebuil...t-drill-chuck/
Why can one not simply employ the use of the wedges? The groove is there and it does appear there is a surface on the chuck for them to bare against.
What am I missing? Seriously point me in the right direction.Home, down in the valley behind the Red Angus
... However it does not mention a procedure for removing the arbor intact, the arbor is essentially destroyed during the process mentioned.
You should now be able to see the end of the arbor through the rear of the body, which can sometimes be driven out with a punch.
It isn’t unusual to find that the arbor is in there so tight that a punch fails to budge it.
Here is an option.... Cut the arbor.. and drill and tap for..."
It sure does mention a procedure for removing the arbor intact.
And an alternative one. If you have a press and a 3/8" pin,
I have always been able to get the arbors out. I think the guy
who wrote the article was a hammer jockey.
-DLast edited by Doozer; 02-02-2023, 12:16 PM.DZER
Great article on rebuilding the Albrecht chuck, thank you. However it does not mention a procedure for removing the arbor intact, the arbor is essentially destroyed during the process mentioned.
Thank you Doozer and mikey553 for the follow up
Yes I focused on a worst case scenario, however with the proper set of wedges I can't see why that method would not work vs. disassembling the chuck.
Mikey, if one clicks on the OP's pic several times the arbor/chuck juncture will be blown up to fill the entire screen, good detail and clarity.Home, down in the valley behind the Red Angus
Originally posted by mikey553 View Post... it appears that arbor shank is smaller than JT taper....The wedges would not work here
Wedge drawing attached. Metric units.
Originally posted by Willy View PostThank you Doozer and mikey553 for the follow up
Originally posted by djc View Post
For a parallel shank arbor that is smaller than the fat end of the Jacobs taper, you can make a split sleeve that goes over the parallel portion. Clamp it up tight with loctite as backup and then apply the wedges in the approved manner.
