Anyone happen to know the trick to reinstalling the spindle CB spring? There is a keyhole type slot in the end of the spring(not clearly visible in the pic) that needs to hook over and onto the flat head screw shown. The problem is not able to see where the keyhole is at in relation to the screw head when sliding the spring/housing over the shaft.
The two little roll pins, one shown in the upper right, don't help the installation process but are necessary to engage the slots in the spring housing to keep it "wound up" after installing.
Edit: The plastic knob and washer are removed prior to installing the spring/housing, of course.
