We've all been there. The ubiquitous side projects needed to make some tool or jig to deal with what we're trying to do.
For me it came yesterday with the need to flute a small sub 3/16 custom tap (vintage .22 rifle screws needed) to permit making a die to thread the screws to finish the original job of getting a few old pump action .22's up and running.
And before you suggest it don't bother telling me about Numrich or any other possible source. I need a surprising number of them (8) and they want the world for them. And it's a hobby, right?
So here's the situation. 3/16 x 48 sticking out about 1 inch. Wobble and bend city if I try to mill them without support. Notice the small dainty center drill in the end which was used during the single point threading.
The little angle plate was a first thought about rigging up a support to fit into the center drill. But this one is too small and would not really work out very well. Next size up is a monster and would foul the spindle and end mill.
But then I thought about the mill table work stop I made a few years ago. Set it up and put a dial gauge to it and pulled. It flexes a little too easily and too much. Close though.... So I cast around and found a couple of handy lumps that with some cleaning up and machining gave me the heavier option. That's a 1.25 piece of cold rolled polished up and checked for size which was press fitted and bolted into the base block that is 3 x 2 x 1.25. So that ain't going to flex enough to notice ! ! !
And a couple of shots of it after drilling and counter boring holes for the post and retaining bolt and the securing bolt.
