what are these for
  • what are these for
    I have seen quite a few indexable tool cutters with the cutter facing to the right hand side and not as usual left what are these for and how do they work I assume the lathe must run in reverse and the tool face the right hand side of the work internally Alistair
    I don't know whatthey're for 'cause I can't see em. Got a photo?
      Rusty try this Alistair
      http://cgi.ebay.co.uk/A-LATHE-TURNIN...QQcmdZViewItem
        Greenleaf sez "90 degree grooving/profiling toolholder.
        I searched part number 411744-312VGS 3-93 (copied from the Ebay listing) at their website.
        Joe
          I have several Greanleaf tools usa made and very good quality Alistair
            Alistair,that tool could be used for normal grooving if you mount it in the front position of a four way toolpost.Alternatively you would use it for face grooving in a cnc where the turret is behind the work.It is not a boring tool.If you have any boring bars of reputable make like that you can send them down to me if you don`t want them.
            Mark
            www.ems-fife.co.uk
              simply a groove tool, I have used similar ones in a swiss screw machine to face,groove and to blend a thread minor to a diameter
                Right-handed Grooving/threading tool.
                I have the Kennametal version of that toolholder that takes "Top Notch"
                inserts: I use acme and v-thread Top Notch inserts for turning internal
                threads, and there are dozens of different Top Notch grooving inserts.
                The same Top Notch inserts are also used in a several different right-handed and left-handed boring bars.
                  How do you turn Acme thhreads on a lathe?
                  How do you set up a lathe to turn acme threads?Do you set the cross-slide to 14 1/2 degrees?Also when starting on the second start how do you turn the workpiece exactly 180 degrees? I have tried but have not been able to get the grooves to come out evenly spaced.
