Originally posted by JRouche
View Post
The 45 deg is for reamers that are to follow and "improve" an existing hole. For a "reamer" that is to essentially bore an accurate hole regardless of the accuracy of the existing hole, which would be the case for a jig borer, the 45 deg taper might be bad, as it could provide a side force trying to shove the reamer into alignment with the existing hole, creating inaccuracy, as well as a non-flat bottom to a blind reamed hole.
So a "jig borer reamer" might look a lot like an end mill, since it needs to "ream" the hole directly on axis with the spindle, regardless of existing holes. In fact, end mills are still used for that sort of purpose, particularly when a counterbore is needed on a non-flat surface, and the like. The existing hole would only be there as clearance for the non-cutting center of the "reamer".
My question to you is how does one determine which is being looked at?
If a manufacturer calls it an end mill, that does not mean it cannot be used as a reamer/boring device. Presumably, the difference may be that the "reamer" is the same thing, but made very accurately as to diameter. Otherwise, if diameter is not precise, why does it even exist, how is it better than a drill?
