I got a D for effort! An actual application for non-circular boring/turning
Originally posted by RB211 View PostYou know clear nail polish exists
sam
- Likes 1
Originally posted by skunkworks View Post
I actually stole my daughters clear nail polish - it was crap. It would start pealing off in a day. So I tried the red nail polish. Its color is 'pucker up' if anyone is interested.. It seems to last a long time.
sam
I like programming oddball operations like this. Can your machine run faster to get the cutting speed up a bit?
I'm currently retrofitting an Emco mill with Centroid Acorn and will have the spindle driven by a servo to do the same type operations although I can't think of many practical applications.
Originally posted by DR View PostI like programming oddball operations like this. Can your machine run faster to get the cutting speed up a bit?
Read spindle encoder -> Figure spindle position based on encoder and index -> calculate the x/y postion based on the shape and tool diameter -> move the x/y axis to correct location -> repeat 1000 times a second.
So - to follow the shape - the machine has to be able to keep up to the calculated position based on the spindle.
I can run it faster and I should calculate the calculated position vs the actual position to get a following error. Just haven't gotten to it.
sam
- Likes 1
I'm sure somewhere I saw a video of a CNC lathe (Okuma?) that was able to turn camshafts and other non-round objects at normal high rpm cutting speeds. The process involved the x axis moving in and out rapidly. under servo control. Apparently the control could handle it.
Originally posted by DR View PostI'm sure somewhere I saw a video of a CNC lathe (Okuma?) that was able to turn camshafts and other non-round objects at normal high rpm cutting speeds. The process involved the x axis moving in and out rapidly. under servo control. Apparently the control could handle it.
I mean - I could run it faster I just don't know how well it will follow the path.
sam
