Getting started with casting has been harder than I had anticipated, but I think I'm to the point where I can make things that are useful.
First decent casting
No I threw that stuff out and bought petrobond. I didn't use facing sand though. I just put the petrobond through a screen.
for the core I split a piece of PVC pipe, held the halves together with hose clamps and packed it with petrobond and some nails. Next time I'll use hardening sand with a vent because I can see where bubbles came out of the core.
I just looked at the picture and I swear it looks better than that in person. I did notice that the top is rougher than the bottom. Not sure what that's about.Last edited by Commander_Chaos; 03-12-2023, 09:00 PM.
- Likes 2
Thanks. Right now I have a little furnace kit that I bought off of eBay and the part shown used every drop of metal from my crucible. We're moving some time this summer by and I'm looking forward to building a much bigger furnace, as well as not working in the basement of a Philadelphia row home. 😐
Originally posted by wierdscience View PostLooks good to me, carb adapter???
Originally posted by Dan Dubeau View PostLooks great!. I still have not done anything with cores yet, but have a few projects on the list that will need them. I want to try epoxy cured cores, and also sodium silicate. Will use 3d printed core boxes, and patterns.
Did you degass with anything before pouring?
The first mold I made was with sodium silicate. Pretty easy to work with but I was using my crappy, homemade sand so there was a lot of sand in the metal afterward. I made a thing to cure the sand with bicycle CO2 tire cartridges but I ended up letting it sit for a couple of days and it was hard as a rock.
I admire your work, I have always wanted to try casting metals, I simply don't have the room for it. May be in my next life 😎_____________________________________________
Oregon Coast
Originally posted by lugnut View PostI admire your work, I have always wanted to try casting metals, I simply don't have the room for it. May be in my next life 😎
