Hi all,
My Trico micro-drop has been plugged up for a while so today I decided to disassemble and clean the unit. That went well but I realized afterwards that the reservoir wasn't pressurizing properly so I pulled the pressure switch and regulator. This is supposed to be one unit but it fell apart when removed and, for the life of me, I can't see what held it together originally. The pieces still fit snuggly when they are pressed together but there are no mechanical fasteners and it doesn't appear to have been soldered.
If you look at the pic, the left side is basically the air supply on/off switch with unregulated ports for the air lines. To the right is the pressure regulator with a port restricted to 8 psi. for the coolant reservoir. The male end of the regulator body slides into brass fitting and does have a small groove that looks like it could possibly hold a small O-ring but none was present.
I think it will work again if I can keep the 2 pieces together but I'm hesitant to solder as there is a needle valve and spring that I can't seem to remove from the regulator body. What do you think, Loctite, JB Weld, epoxy?
Plan B is to scrap the original assembly and just plumb in a separate regulator to control the reservoir pressure.
Thanks!
John
Thanks!
John
