DRO for mill recommendation?
  • #16
    Originally posted by burdickjp View Post
    I've had 2 touchDRO installs and they're fantastic to operate, especially compared to anything out of China. I especially like the tool table and work offset capability.
    Is that complicated to use?
    I watched Blondihacks install hers but she's miles ahead of me with computer and electronic experience.
    Len
    • #17
      I've had 2 touchDRO installs and they're fantastic to operate, especially compared to anything out of China. ....
      Where do you think these tablets come from? Timbuktu ?
      -D
      DZER
      • #18
        Not sure Touch DRO is any cheaper when adding a tablet. Looks like $129 for the plug and play interface.
        • #19
          Yes, Mark Presling did a cost comparison. Might be different in Australia, but it came ouy about the same either way. TouchDRO probably won't save you any money, unless you already have a tablet in search of a job.
          A touch screen might be nice, though. The buttons on my Chinese DRO are a bit stiff. I thought I built a fairly rigid mount, but I usually support the back of the unit with my fingers and press the buttons with my thumb, at least the ones I can reach that way.​
          • #20
            So again, do these Touch DRO's require any circuit assembly or software programming, etc.?
            My only experience with DRO's is the Teledyne Gurley Pathfinder on my mill.
            Len
            • #21
              I went with a Sino scales Ditron would be good to then used a LCD display. I should have bought a kit setup that way to make shire they are wired correctly had to rewire them. China has 4 or 5 different wiring diagrams they use.
              I have this one but with Sino scales
