I'd have probably used a spring plunger or ball, and made it so all that had to be done was to loosen, turn, and tighten. As far as I know, that is how most of the indexing posts did it, and it would suit what I do.
I tend not to like pins that need to be removed and put in a different hole. Sometimes you have to, sometimes not. Do you plan to make the pin tapered so that it can be a tight fit?
