Here's a fun little project I recently completed. After every little casting session I do with my benchtop foundry, there is usually a bit left in the crucible that I dump off into an ingot mold, only to end up in the crucible again for the next pour. Small volumes, but it's always bugged me as being a waste. I got thinking of some simple small volume shapes I could cast and make permanent dump molds of and maybe shift away from just dumping off ingots all the time, to creating useful parts instead. A dump mold is usually a simple shape to dump the waste in. It doesn't have the complex sprue, runners, risers, etc of a permanent mold, it's simple a cavity to "dump" whats left into. This is the first of a few different ideas I had.
The threaded inserts are 0.75" od x 1" long and tapped 1/4", 5/16, and 3/8" unc. They ride in straight 0.751" reamed bore and can be set at different height for different shoulder lengths. I'll make some metric ones too as needed. Simply wind in a bolt of the size you want and it get's captured by the pour. The natural draft of the cavity is the rads of the lobes connecting at the parting line, and I'm relying on shrinkage to release from the straight sided shoulder bore.
First test didn't go as planned.
Seems there are some venting issues that didn't allow the lobes to be filled. The rest of the mold worked as I imagined it, so it was time to do some modifications to the sprue and venting. The excess on top is easily cold chiseled off allowing the part to come free of the mold.
The sprue is easily faced off leaving a flat surface. Tiny bit of porosity in the center.....
Back to the drawing board to modify the venting and open up the sprue, this is what I came up with.
and these are the results. I opened the sprue dia up to the max, and vented the entire flat top out. I wanted to keep the top opening round to aid in the chiseling off excess or else I would have just cut the lobed shape straight up.
I also added some 0.003x0.337" parting line vents out the side of the lobes
First pour in 1/4" this time, and all lobes filled perfect. Success......
When it came time to face it off however.....
I'd consider it a 90% success for the intended goal which is to better utilize that small volume left at the end of a pour instead of dumping off ingots to remelt again. NOT make 100% perfect thumbscrews trying to put carrlane out of business....... I don't think I'll ever 100% get away from the porosity in the center because I don't have a feeder to feed that core as it cools. For most of my regular casting sessions with my little benchtop foundry there isn't enough volume left at the end of a pour. I might not ever get 100% fills of this mold, but it'll be worth giving it a shot instead of just dumping off ingots all the time. It won't take long to build up a little inventory of various sizes that are handy around the shop for tooling builds, or for use with my lure/jig molds.
I have a few other ideas for simple small volume items that I can also make dump molds for and will share them too when I get there. I won't do anymore dedicated pours to test this one though and play around with it more, it'll have to wait until the next casting session. Not sure there's anything I could really do with this to mitigate that, but I might turn a pouring tube to act as a bigger riser on top to feed that cavity as it cools better. Not sure I'll have enough volume to fill it all the way, but it would probably help. I also thought about machining down the top of the mold to almost get rid of the sprue entirely and force the shrink bubble deeper below the surface. If that doesn't work I have to re machine the upper mold half so.... I'll pour a few more during the next casting sessions and go from there. I can also just simply plunge a ball endmill in the top to turn it into a design feature too.....
Cheers, Dan.
Cheers, Dan.
