I have a partially working copy of a cnc program, you can import gcode, export, cut and freehand cut with joystick (saves moves and speed). I don't have the time or the current programming ablility to complete.
Anyone want to finish it in Visual basic for me? it would be cool to post it like they have linux. Freeware.
This Job I am on, making good money but time is at a premium.
My poor machines in the shop are getting rusty.
I'll share for the return of any modified versions with code. I have hundreds of hours in this already. Most things are basic, using a driver to send data out the parallel port. Saves gcode files in ascii format. Configuration is set up the same on the port pins as the Qstep program currently in operation on my brideport cnc. Steppers.. Gecko drives, inverter,
This software should work anywhere on a stepper based machine. Lathe, mill or drill. First machine was just a pcb driller and worked great. I traded up to a bridgeport.
