acme thread mill
  • acme thread mill
    I've been looking for an acme thresd mill. Does anyone out there know someone who makes one. Thanks
    Are you looking for the whole mill or just the acme threaded rod?
    A lathe will make it.
      I'm guessing he is talking about a thread cutting mill...as in milling cutter, not milling machine. I know they make them for standard threads...not sure about acme.
      paul
      Paul Carpenter
      Mapleton, IL
        Seeing that Nook sells milled acme thread lead screws they must exist.
          Try this:
          http://www.advent-threadmill.com/tech-des-02.cfm
          Half way down the Column 4: listing. This may be a start. Lloyd
