Something like this?
OT: Best DIY epoxy floor
I'm not at all fussy, I'd really just like to have the option of cleaning up from time to time instead of a big, permanent, greasy mess. I don't have to have every speck of dust off the floor to feel like I'm a viable human being, either. If I can throw down some sawdust or kitty litter and get the oil off I'll be plenty happy.. If I drop a screwdriver and chip the paint I won't care, no matter how hard I try.
Only floors I have seen hold up to floor jack and truck traffic were epoxies with a lot of solids. The weight of the buckets were very heavy and the epoxy was troweled on. Floors as others have stated were acid etched and in some cases shot peened. Most DIY floor coverings are not good enough for long term wear IME.
👍 1
Originally posted by Commander_Chaos View PostI'm not at all fussy, I'd really just like to have the option of cleaning up from time to time instead of a big, permanent, greasy mess. I don't have to have every speck of dust off the floor to feel like I'm a viable human being, either. If I can throw down some sawdust or kitty litter and get the oil off I'll be plenty happy.. If I drop a screwdriver and chip the paint I won't care, no matter how hard I try.
I used the Rustoleum 2 part epoxy from Home Depot and have very good results. My floor was a year old but not used yet. Even so I was not pleased with the trowel marks that were left so I put a diamond surfacing wheel on my 7" angle grinder with the vacuum shield kit. I sat down and ground the entire 10 x 22 foot floor to remove any imperfections. I ground out and filled the few small cracks in the surface. Then I used the recommended etcher. This process really opened the pores on the concrete and the product did not spread at nearly the rate it was supposed to. I ended up racing to the store to buy one more kit!
The instructions said to pour a certain sized puddle for so many square feet. But it stuck to the floor so tightly I could not spread it far enough with the provided solid roller. If I were to do it again I would just use a roller pan like normal paint rolling. It all ended well and has been very resistant to any damage for several years now. I spilled some epoxy on the older part of the garage floor and even though that floor was not cleaned at all I had a devil of a time removing the spill. The diamond wheel was the only thing that worked. This stuff really sticks.
If you're having fresh concrete poured, I'd highly recommend looking into densifiers. Instead of a paint or epoxy coating, you can use sodium silicate and get a polished finish. It's extremely hard wearing, dustless, and doesn't take oil stains easily. Our production facility has polished floors and industrial epoxy floors. After 40 years, the polished floors are still great but the epoxy floors look like hell.
👍 2
Originally posted by Fasttrack View PostIf you're having fresh concrete poured, I'd highly recommend looking into densifiers. Instead of a paint or epoxy coating, you can use sodium silicate and get a polished finish. It's extremely hard wearing, dustless, and doesn't take oil stains easily. Our production facility has polished floors and industrial epoxy floors. After 40 years, the polished floors are still great but the epoxy floors look like hell.Avid Amateur Home Shop Machinist, Electronics Enthusiast, Chef, Indoorsman. Self-Proclaimed (Dabbler? Dilettante?) Renaissance (old) Man.
Double check what you put on the concrete floor. We have one building 45x40 metres and it has a very nice gray 'paint', it is oil proof too and engine oil, hydraulic oils etc do not soak in.
However it has one flaw, it is not water proof! Park a vehicle with wet tyres and it will lift the paint after a day or so!
Back in the day, before there was epoxy, there was floor paint. Got some in my basement. While it's probably true that paint back then (1958) was probably better, it should still be possible to find a decent floor paint without resorting to epoxy. Couple weeks from now I'll be hoping to find some.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
