I went to use this drill press. Motor, fine. Rotating but not driving anything. The belt seems waaaay loose. Before I start pulling things apart, a few questions:
This uses a Reeves Drive pulley system. My first instinct was that the belt is old and ... stretched out? Is that even possible? Even if so, not this much, I would think. Does that indicate that the expanding/compressing pulleys are to blame? I've read about the pin on these models for the rear upper pulley coming loose. Unfortunately, I did not check that. I can tomorrow. The extension of the motor is as far back as the locating screws allow.
Thoughts? Experiences? This is a consumer grade product. The manual simply lists, "call our help line" for any and all troubleshooting. Haha. It doesn't even identify the size belt that is standard, which I'm not truly confident this one is? Can anyone confirm?
Many thanks!
Many thanks!
