Originally posted by npalen
View Post
That Hemingway thing is just a clutch. You are supposed to feel the lever in one direction, while needing to hold it in position in another direction, so as to apply just the right torque. Connecting the two with a loose lever is not the best plan.
Can that be done? Sure. Can you do it perfectly 100 times in a row? For a 4-40 or 2mm tap? Well, that's a different thing.
And no, that is not similar to power steering.
"Torque limiting" would mean a setting, i.e. a "meter" that measures torque and releases at a given torque.
Originally posted by Paul Alciatore
View Post
A device to MEASURE the applied torque, NOT a device to APPLY a given torque. But no matter, it's not a good idea compared to other possibilities, as mentioned.
