Looks like I get to replace the water pump on my 40 Hp 4 Stroke Yamaha. I had a weekend planned on the lake. Now looks like a driveway project. Have the "official" Yamaha kit coming today, have the repair Manual and watched a couple You Tube videos so I think I am ready. I find out this is suppose to be a every 100 hours thing, and I don't think the previous owner did anything on the boat since 2008!
Fun Week End Yamaha Outboard
Originally posted by A.K. Boomer View PostThat's insane, Wonder if it's due to corrosion, them stilling for such long lengths of time half wet, sounds like your well overdue, So why the decision in the first place did the old one shell out?Retired - Journeyman Refrigeration Pipefitter - Master Electrician
100 hours sound about right- the pump sucks in all kinds of debris, no matter how the intakes are screened, on a fishing boat the motor gets tilted often enough that dry starts are a daily thing, or gets to sit dry for 4- 6 months. Looking back, I'd say all of our OMC outboards probably ran 100-200 hours between pump replacements.
No or very very low water flow. Overheat alarm. My big problem now is getting the lower housing separated. All I have is WD40 and it sucks as a penetrating oil. Nobody in town of 60,000 people carries Kroil had to order from Amazon. Yes I have all the bolts removed, and tapping with a brass hammer so far has done nothing.
I no longer have a boat. My last was a 50 hp Mercury, which was a bitch to change ...particularly for someone only doing it once in a blue moon. I suspect it's the sort of thing that would come easier the more you do it. I seem to recall the OMC products were a little more mechanic-friendly with the water pump design. Maybe I'm mis-remembering.
In any event, given the option of: a) paddling back to the boat launch, or b) burning up the engine, or c) biting the bullet and spending an afternoon rolling around on the driveway, the decision process becomes pretty simple.
It would seem like the length of time the impeller has been in there would be a better gauge of when to change than total operating hours. ...more time for rubber to age and harden and deteriorate, etc.Lynn (Huntsville, AL)
Thinking now this has never been apart, drilling and tapping a 1/4-20 access hole in leg. Aluminum and not to thick and I can measure to miss the shafts. Then I can spray the heck a lot of penetrating oil inside and let it soak as long as it takes.
There is likely a set screw on the shift shaft you have to loosen.
Use plenty of grease when you put it back together, including in the cup and on the impeller to help it get broken in without losing a bunch of rubber and heating up the cup.
If its a trailer boat the corrosion shouldnt be too bad?
- Likes 1
I think most intake screens are off the the side some but some are directly up-front maybe just for that purpose or to help the pump do it's job better when it's needed after all the highest full throttle demand for cooling would be the boat also getting up to speed, unless your towing something then your screwed... (without a pump)
I think the pitfall of having the screen directly up front is plugging, to some degree side screens would be a little more self cleaning that way...
