Boring Bar Head
  • Boring Bar Head
    I just picked up Boring Head for my mini mill, it's MT2 shank and came with a 9 piece set of boring bars. I got it from Lathe Master. The set was &79.00.
    I know the basic use of this boring head, but does anyone have any tricks or care and feeding suggestions?
    Jerry
    Perhaps the most basic is to run it slowly enough when doing large holes. If you work out the feet per minute, you quickly discover that a boring head cutting a 2" hole in steel should be about 200 rpm, max. Add to that the amount of overhang and imbalance, and slow is Good.
    The M2 shank has provision for a drawbar, I hope.
      Keep the gibs snug, lock the axis once aligned, and keep the quill snug enough to offer some resistance to the downfeed. Holes will be rounder.
        This head does have a provision for a drawing bar. Slow is the way the way to go.
        Thanks for the advice.
        Jerry
