Todays haul
  • Todays haul
    This is getting embarassing.
    A 15" Bridgeport rotary table which, I must add, is grotesquely heavy and I'll readily swap for a more reasonable size.
    A 5" graduated, tilting/swiveling milling vise from the old New Britain Tool.
    And last a device I'm not quite certain the proper name of but I guess it's a rotary indexer with a 6" Union Tool steel chuck and it has a plate with holes behind the crank handle. The entire assembly swivels within itself from horizontal to vertical.
    I reckon I'd better get serious about machining what with all this swag.
    Len
    That last item would be a dividing head. There should be more than one plate for it, usually three.
      Dividing head!
      Yes, thank you. Couldn't think of it.
      Three plates then? I'll ask if those are around.
      This is really something, isn't it?...when you start thinking of all the things you can make with these. Amazing.
      And a salute to all you who know how to use them!
      I'm struggling but having a ball none the less.
      Len
        If it is a Meca dividing head then it would only have one plate. Meca put all the holes on one plate using both sides of a thicker than normal plate. If the dividing head uses 3 plates and you can't find the other 2, they are not that hard to make especially if you now have a rotary table.
        either way you scored some useful stuff.
        Mark Hockett
        Mark Hockett
          congratulations, may the machine tool force be with you
            Awesome, there is hope!!!
