The holes are spaced 15 degrees and probably will add a couple "vernier" holes to the block to get it down to 5 degree increments. The ring of holes is about 1-3/4" from the headstock sidewall. The vertical line is an interior rib of the casting that I can straddle with mounting bolts for which I will drill and tap
Any ideas are appreciated.
