Originally posted by Mark Rand
View Post
Remove surface grinder wheel hub from tapered spindle, how to?
👍 1
Originally posted by john hobdeclipe View PostMost tool grinders and smaller surface grinders that use interchangeable hubs will be "Standard Taper" of 3" per foot and 1" large diameter. There are exceptions. Cincinnati Taper is different, and the hubs for Delta Rockwell "ToolMaker" grinders are different, to name a couple. Standard Taper hubs usually have threads for a puller.
But there are some imported machines that have a taper very similar to the 3" / foot, but don't use a puller. The instruction manual clearly states to remove the locking nut or bolt, then strike the end of the shaft using a brass or hardwood block.
That 3” per foot taper is theoretically into the self-releasing range, so why do they sell pullers for the hubs? Shouldn’t need them, right? The hubs should fall right off. Well, even with good spindle bores and hubs they usually stick pretty nicely. Same with the NMTB40 taper in my mill. The mill, of course, has a drawbar to rap on to pop the toolholder. Too bad the grinder doesn’t, but as it’s a different arrangement - with the male taper on the spindle - that wouldn’t work.
