OT: Mechanical puzzle
  • #46
    Originally posted by Elninio
    the force of tension in the wire is 100 lbs, picture it as a tug of war between the wire , 50 lbs in each direction, the pully in this case is just directing the motion. Another way to think of this is as if instead of 50/50, you then had 70/30 and then 90/10 etc.. until you came really close to 100/0, in that case it would be the simple case of a weight on a straight wire of 100 lbs.
    Elninio,
    Based on your assumption, if you hook one end to the 50# weight, and the other end to the ground;
    The tension is the weight of planet earth, plus 50#?
    Just wondering.
    Kap
    • #47
      Things must be slow if we get three pages of drawings blocks, strings and pullies instead of making the bloody thing..................
      I already did John.
