Top Three Hand Tools, Machining related please. Back yard tools are included. Hammer.
What I refer to is here on the farm it is not unusual to be 30 minutes from the shop or trap wagon. Each rig has minimal tools and to think that each tractor or other rig would have a full set of tools is fantasy. So I'm often out with a minimal tool set to do simple fixes. If the adjustable has to work as a hammer to save 30+ minutes of downtime then it is sacrificed to the job. Saving lost downtime will replace a lot of tools modified to get the job done.
lg
no neat sig line
This is precisely why I hire professional mechanics, and not farmers to repair my vehicles.
12" x 35" Logan 2557V lathe
Index "Super 55" mill
18" Vectrax vertical bandsaw
24" State disc sander
I'd have thought that the one tool every tractor/rig would have would be a hammer.
'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
Yup, they used to. Nice long handle blunt head mallat, Doesnt have to be too heavy, just enought to feel and hear if a tire was off (PSI) or dead. You want a light hammer for that, it gets heavy after a few inside tires, JR
Oh, only on the trailer tires, not the truck. The truck has Michelins, best tire on the road, I think.. JR
Yeah, me too, every time. I had severe dyslexia as a kid, and to this day transpose letters and numbers. Much easier to double check with a calculator than make the parts twice because I made a mistake in my head. Besides, I keep my mind sharp with hookers and blow.
I have always had visual dyslexia. With my situation, I can usually tell the instant I have reversed something
and I go back and correct it. But for some reason, I have to make the mistake, before my brain will
recognize it, to correct it. So for me, doing arithmetic on paper keeps the detection mechanism in my
brain sharp. For me, I can transpose numbers punching them into a calculator more readily than writing
them out for some reason. Good thing I am an engineer, and my mis-calculations can only kill somebody,
rather than if I were an accountant, and my mis-calculations might loose the rich man his money.
X3 on that. One of the reasons there is minimum tools on a tractor is there is no where to put them. Recently I bought a new 115HP 32 speed tractor and it just has 2 little boxes for pins and such on it. Not even a place for a grease gun.
On rigs and large trucks it used to be common to carry a piece of pipe to check the tires (and for protection). It also was used for extra leverage on snap binders.
