Which stainless steel to order?
  • Which stainless steel to order?
    I am getting ready to make the table for my belt grinder. It utilizes rods as part of the positioning mechanism. They need to slide so I thought SS would be best because of rust. Which type would be the best against rust and also best for machining. I need to mill 8mm groves lengthwise with ball end mill..
    Don't use stainless - it may not rust but there is always a chance of galling and picking up if you use it as a slide.
    I would suggest buying some linear shafting instead and use that - it's designed for guideways. It's hard (more like case hardened) but easily machinable with carbide
      You could avoid any danger of galling if the stainless is bought ready ground and used with matching size readily available thinwall split bushes which have a PTFE bearing surface. They are used dry and as long as the grooves are deburred they will not be affected. The design could incorporate easy bush replacement. I would use a carbide ball end mill for the grooves.
        Black forest .what are you using for the platten.?
          As long as you don't need to weld it, I would go with 303. It's stainless enough, not going to gall, easy to machine and readily available.
            300 series SS does not wear well. If you expect a lot of movement I'd go with 17-4
            Southwest Utah
              For the ultimate, go with Thomson 440c stainless linear motion shaft.
              When it comes to 440C Stainless Steel Linear Motion Shafts, you can count on Grainger. Supplies and solutions for every industry, plus easy ordering, fast delivery and 24/7 customer support.
              It's all mind over matter.
              If you don't mind, it don't matter.
                BF- Knowing and understanding the design and application, I would use a 303 material.
                It should be fine for what you are doing.
                Sid
                  Another vote for 17-4, very good wear resistance, galling and corrosion resistance is better than all of the other commonly available hardenable stainless steels.
                  It also welds very well if that is a consideration.
                    Is the environment that corrosive that it needs stainless? Just wondering
                      I think climate wise moist air and unheated shops = rust, it’s a problem where I am, sometimes it’s a thick wet fog for weeks at a time, condensate on any steel.
                      annoying and I find it depressing to the extreme.
                      I don’t think it matters what stainless, it’s not moving that often 303 as mentioned machines well my platten is topped with ceramic at the moment, basically a porcelain tile stuck on with silicone mastic!
                      mark
                        mark
                        Like you, I'm in the UK - in Suffolk about 15 miles from the North Sea coast - so we probably have similar-ish climates.
                        But I've never had a problem with rusting on any of my equipment - perhaps they just have more oil leaks that prevent any oxidation 😀.
                        But as a mechanical design engineer (high-speed rotating equipment and robotics) the thought of using a bar of ordinary stainless for a reciprocating guide shaft does horrify me quite a bit, particularly when a piece of hardened linear shafting is close enough in price to replace it with.
                        Of course there is always the option of hardened & ground stainless linear shafting - maybe the best of both worlds?
                          Aluminum?
                          Golden Triangle, SE Texas
                            I do have a problem with rust in my shop. Maybe I will buy some hydraulic rod in the dimensions I need. The problem with that is milling the grove with a ball endmill. I need to mill six groves in 3 bars. Two each. I am not sure how well even a carbide ball nose endmill will handle the chrome and induction hardened outer layer of the rod.
                              Also I don't know where to buy that fancy rod here in Germany. It isn't about the cost it is about not rusting and machine-ability. I only need about 500mm of 30 and 25 mm rod.
