Originally posted by RB211
View Post
Well I guess that settles that!
Originally posted by Bob La Londe View PostI smiled when I saw the comic posted on Facebook. I started out with CNC machines and now I own several manual machines as well. When you gist need ta waller a hole in something that ain't no point in taking all the time to sit that on that there computering thing and sit there and wright a big old fancy detailed program.
Everything would be the same effort manual or CNC until you got to the actual drilling. The CNC would excel because of the choice of drilling options. If the hole is deep you'll have time to clean off your work bench while the drilling is happening.Last edited by DR; 09-14-2023, 11:21 PM.
👎 1
Originally posted by RB211 View Post
So you never used a sine bar before or a tooling ball?
Originally posted by DR View Post
You must have gotten your CNC experience back in the dark ages. Simply drilling a hole would probably be better done on a modern CNC than on a manual machine. No need to sit down at a computer or write a big old fancy detailed program. All data entry would be done standing at the machine. You would enter the coordinates of the hole with respect to some position on the part. Then use the drill cycle, in the drill cycle you could choose straight through drilling, chip breaking or step drilling with full drill retract to clear chips between pecks, plus the option of a dwell at depth.
I don't know all the details of every single g code but I have been known to stand at the machine cutting stuff entering code at the MDI interface one line at a time while the machine is running the last instruction I entered.
There are times when even the humble drill press is faster to get a job done.
Bob La Londe
Professional Hack, Hobbyist, Wannabe, Shade Tree, Button Pushing, Not a "Real" machinist​
I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
