You have probably all seen by now that I tried to build a "cross beam flame licker" engine and failed to get it running. I made two different cams for it, and took advice from several well intentioned people, but it just wasn't going to run. I have spent a happy day at my computer, designing a new four cycle gas engine which will be built using almost all of the flame-licker parts without modification. Other than the sideplates and the smokestack, all of the other parts get a second chance at life. I haven't sussed out the intake and exhaust yet, but that will come tomorrow. I love a day when I can set at my computer, uninterrupted and design a new engine based mostly on parts that I already have. Will I build this engine?--Yeah, probably. The alcohol tank will get a repositioned fuel outlet and become a gas tank.
One interesting thing about this engine is that it doesn't really have a camshaft. In order to keep everything aligned vertically and not have the con rod passing thru the camshaft, I am running a double set of gears mounted on shoulder bolts.
