I needed something to mount on the table saw to hold square inserts. These will be mounted at a 45 degree angle such that when it is spinning, it will cut a groove with 45 degree sides. It needs to be able to go nearly 1/2 inch deep, and I've determined that the square inserts I bought are just barely able to do it. I started with a piece of 3/8 thick x 2 inch wide flat bar, 6 inches long. Carefully marked and drilled a 5/8 hole for the arbor, then sawed away the steel that wasn't part of the design. I milled two flats where the inserts will mount, and I have a jig gluing up that will let me mount each insert in the exact same place on each arm so it will be balanced, and both inserts will cut.
What I'm hoping to do is carefully mount both inserts, then JB weld a notched piece on each arm that nests up to the insert. This will form the 'pocket' for the insert to set into, and will keep the 45 degree angle correct. Once the JB has set, I'll drill through the notched pieces and into the arms so I can tap for a holding screw. I'll JB the screws into place as well. I may not do it in this order- I might drill and tap before I mount these 'pocket pieces', but I'll still JB these pieces and the screws that hold them into place.
This will give me a tool that I can mount on the table saw and use to cut the grooves I need without having to angle the blade, or come up with weird jigs to hold the material while I cut. Yes, I could set up a router to do this job, but I want to be able to do it with the table saw.
This will essentially be a two toothed blade, so it will be choppy, but it will get the job done, and accurately. I know people will say this is not safe, but it's not going to come apart. To be sure, I'm not going to be standing inline with the blade while I fire it up, and I'm cutting wood only, not metal.
In the end I'll be passing thin plywood over the cutter to notch just a tad into the face on four sides, then I tape over the notches and turn the piece over to notch more deeply. The second cut goes through, but doesn't have to breach the top side of the plywood, so it won't cut the tape. The four corners will fall away, and I'll be left with 5 pieces held in alignment by the tape, which I then glue and fold up into a neat box. I've done this before, and it works great- but only for material thinner than 1/8 inch, and only with a blade with flat topped teeth. This tool should make me happy.
