Prehistoric Analog Profilometer?
  • Prehistoric Analog Profilometer?
    Here is a piece of history, a custom built machine to check the profile of 155mm shells. Came out of a defunct Army Ammunition plant, about 40 years ago now. No mfgs name on it, just a big x and z axis with a rotary A axis. Apparently the way it works, the shell was placed on the rotary base, the cycle started and a stylus wheel checked the runout and dimension at various points an inch apart.
    The stylus tip can be seen at the bottom of the vertical arm to the left of the column. It's just a wheel, attached to a slide with a mechanical limit switch attached.
    There are two, what looks like calibration standards on the machine.Each is a series of pins machined and set to an exact protrusion that describes the profile of the shell.
ID:	2062937 Click image for larger version
    I don't have any pictures of the control cabinet, it was scrapped out awhile back. But it consisted of a couple power supplies, an 8 channel paper chart recorder and a bank of toggle switches.I'm guessing this would be done by a CMM of some sort these days.
    I would imagine that the same technology used in gear tooth checking ( master gear and a ldvt feeding a chart recorder ) it must have worked I suppose.
    lots of shells must have gone through the testing machine, interesting kit.
    mark
      I had a dig and saw a bit of the armoury making shells for the Missouri battleship, wonder if the things got checked on this machine, it may be historical, who knows
      mark
        mark
        I don't think so, Navy would be either 5"/38 caliber or 16"/50 caliber. Too big for one and too small for the other
