Here are a couple of tips some on this list may find useful. I bet others have some they think are common knowledge or not worth mentioning but others will find useful.
I put this one in the unusual tool thread, but I’ll repeat it here. I scored a good deal on Kennedy tool chest at a local pawn shop a couple of years ago. The price was good but not great. What made it worth while was it came with a drawer full of M2 lathe bits. As a toolmaker (aerospace composite) and patternmaker I routinely use machine tools, but not on a continuous basis, also, in commercial operations tooling is almost exclusively carbide so I’m not as accomplished at grinding single point tools as I’d like to be. These bits are all unused and look like the examples in a text book. Whoever ground them knew exactly what he was doing. There is no hesitation marks or indication of an unsteady hand on any of the various geometry. I haven’t used any of them and don’t intend to. What I do use them for is as readily available examples of what the bits I grind should look like. For that, they’re invaluable. Having an example to work to is a great help. I do this with fishing flies too. I’ll buy a quality example of a professionally tied fly and use it as an example to work to.
My second tip is one that I came up with the other night. It’s probably not new, but that doesn’t mean that I didn’t invent it again yesterday. (Ala Star Trek) In setting up and tuning my lathe in a new location I’ve mounted to studs in the floor and accurately leveled it, but wanted to tweak in the alignment of the tailstock. Here’s what I came up with: I chucked up a piece of readily available bar stock and turned a 60* point on it. With the dead center in place I moved the tailstock very close to the point I just turned and locked it down. Holding a thin parallel (any short, thin flat piece should do) between the centers, I advanced the tailstock feed until the parallel was lightly held in place between the centers. Sighting down from the top, I could see the parallel was slightly askew from perpendicular to the ways. I then adjusted the tailstock by a few thousandths until the parallel was perpendicular to the ways. No indicator was required as a very small change in the tailstock produced a significant change in the parallel’s alignment. I’ve used this same principle to place the point of the lathe bit on center indicating the parallel until it’s vertical (not an original idea) and adapted it to positioning round stock on center with a mill or drill press spindle. All that’s needed is a pointed tool (won’t work with a flat contact area). It also works better with smaller diameter workpieces since the error in picking up the tangent point is minimized.
So what are you’re setup tips?
