Thread Pitch?
  • Thread Pitch?
    I'm in the process of buying an internal threading boring bar.The problem that I have is that I'm going with a Kennametal laydown LT system and the inserts that I can chose from has a 1.0 and 1.5 thread pitch.I'm only going to be threading coarse threads and in std. sizes.App. 3/4" to 1 1/2" bolt sizes.Any pitch sizes would be greatful.Thanks
    Frank, not sure what you're looking for?
      looking for the correct insert that i need is it the 1.0 or the 1.5
        So, all you're going to do is Metric 1.0 or 1.5mm?
        I guess I'm cornfused too.
          I'm not sure either but if you're asking what is the best pitch for machining bolts of the 3/4 to 1-1/2 inch size you will probably want something closer to the standard pitch of a 3/4 inch bolt in a coarse thread. When you finally get to the 1-1/2 inch bolt you'll be at a fine pitch for that diameter.
          a 1mm pitch is 40th American (actually .039371) which is 25.4 threads per inch. Thisi s much to fine for the bolt sizes you specify. A 1.5 mm pitch is 16.93 threads per inch (TPI) and is still fine for those diameters but a better choice. A larger metric pitch, say 2 to 3 mm is better yet.
          Rob Dee
            Can you offer more information? I have looked at Kennametal LT Laydown tooling in a couple of catalogs, and see no reference to 1 vs 1.5 pitch. There is something regarding (I think) the helix angle and that may have to do with the pitch of coarse vs fine threads. The inserts do come specific to a range of thread counts.
            Jim H.
              Frank,
              Like others, I'm a little confused by your question.
              With the laydown type insert you can get a general purpose insert that'll cut anywhere from something like 8 tpi (threads per inch) to 16 with the same insert. You also get inserts that are called full profile, where a different insert is required for each different thread pitch.
              I'm guessing your question may be based on the fact the dealer you're working with only happens to have the 1.0 & 1.5 in stock. Those are metric inserts full profile types, since you mention 3/4 and 1-1/2 I'll assume you're aren't working much in metrics so those wouldn't be a good choice for you.
              With the popular laydown style insert system there's a wide variety of inserts readily available from dealers. J&L Industrial and MSC are a couple online places that'll have them. When buying be sure to find a dealer who'll sell in less than box quantity, that way you won't be forced into buying full boxes of ten.
                Threading inserts
                Hi! If you look at the Iscar threading inserts, You only have 2 insert sizes....the small inserts will cut any thread ( 60 degree thread) up to about 8 TPI... the larger inserts will cut the deeper course threads....Kenametal should have a similar system.
