Fluting Barrels
  • Fluting Barrels
    How do you get a good finish when fluting stainless rifle barrels and any tips. I just did one using a solid carbide end mill with the head of the bridgeport tilted 10 degrees or so to allow the cutter to clear the chips better and cut better also. What a **** finish. HM. Any tips perhaps a arbour and slitting type cutter would of been better. Any hints guys thanx Mike
    Number one is the rigidity of the setup. The barrel has to be supported every 4-5 inches. A horizontal mill with an arbor and outboard support will produce the best results, but they can be done succesfully on a bridgeport, that's how our prototypes were done. We used a form ground arbor mounted tool. the form is similar to a gear, but with a radius on the end rather than a flat.
    The full profile with a form tool can be done in one pass with LOTS of oil (for cooling) and a solid set up.
    Personally, unless you just have to have the fluting because of asthetics, I wouldn't do it. Its too easy to put unwanted stress into a barrel. If you are looking to save weight, go with a smaller barrel.
    Ignorance is curable through education.
      While it may be a neat project to do, and if you're looking for ultimate accuracy, have the barrel maker flute the barrel. He will do it, stress relieve and lap after it's all done.
        I fluted a barrel on my Van Norman #12 using a gear cutter in horizontal mode, it worked well. It is not the best way to cut a flute, since the shape of the cutter takes a bit out of the exterior, but it looks nice.
          DITTO-
          I fluted a used .308 SS bull barrel once just to say I tried it. I took my time and I thought I did it right. It's cold bore shot after being reassembled was 3" off of pre fluting at 50 yards = 6 MOA. I adjusted the POI with the scope, but the groups wandered in all directions once it warmed up. I had effectively destressed the bull barrel allowing the barrel length to wonder to least resistance when heated up. It looked cool but I wouldn't do it again. Oh and I only saved 7 ounces with the removed fluting material.
          Duke Reno / Yankee Metallic Metalcraft
