On the weekend, I was reading a book on cutting screw on lathe, and it was describing in detail the mathematics of gear ratio for inch/metric screw cutting, and the potentially inaccuracy introduced by the gear ratio not being precisely correct.
Are there lathes, where the leadscrew is driven by a separate servo motor? If you had a high resolution shaft encoder on the spindle of the lathe, you should be able to digitally create any ratio you needed with extremely high accuracy. Better yet, the servo should have the feedback coming from the DRO so that any inaccuracy in the leadscrew pitch can also be compensated.
More day dreaming about machining utopia.
Albert
Albert
