First of all, thanks everyone! I've learned a lot by lurking here since I picked up a little lathe and a mini-mill last year.
A friend of mine picked up an old pump action .22 that he wants to cut down into a carbine, and I have a couple of questions. Are there any tricks to crowning the barrel afer It's cut down to size? I plan to use a freshly sharpened bit for my finish cut, but I still wonder about deburring it without screwing it up. The other thing I need to do is cut a new dovetail for the front sight. This should, of course, end up on the top of the barrel after everything is put back together. I figure that in this case I can just use the existing dovetail for reference (if I can remember to do that before I cut it off), but how would you go about this if you didn't have that option? And last. What is THE first gunsmith book to get.
Thanks again,
Rick
Thanks again,
Rick
