Motor question
  • Motor question
    What type of motor is this?
    180 vdc shunt wound GE motors Name plate info: HP 2 RPM 1750 Volts 180 Arm Amps 9.5 Wound shunt Fld Amps .48 Insul class F Duty cont Max ambient 40 c Fld volts 200/100 Type CDL186ADY Encl TENV INSTR GEH3967 Mod 5CD144SD818B800
    Edit to remove any hints of me trying to sell something
    I have 2 180 vdc shunt wound GE motors for sale. I will sell both for 500.00 or 250.00 for one. Name plate info: HP 2 RPM 1750 Volts 180 Arm Amps 9.5 Wound shunt Fld Amps .48 Insul class F Duty cont Max ambient 40 c Fld volts 200/100 Type CDL186ADY Encl TENV INSTR GEH3967 Mod 5CD144SD818B800
    Also edited after looking like a pratt which given as it's a Tuesday isn't unknown
      I am not advertising. I found that ad so I cut and pasted to save on typing. 598 now
        Sorry,
        Removing foot from mouth, fitting it into milling vise and removing 10 thou
        Ouch.
        To make ammends I'l try to answer it.
        They are DC motors shunt wound with 4 leads as opposed to permanent magnet types with two leads.
        Field voltage adjustable from 100 to 200 v Dc and armature is 180v DC
        These will need something like a KB controller to run them.
        Sound expensive at $250 I think I have seen similar on Surplus Shack a lot cheaper.
        Not sure as being in the UK many of the US sites don't interest because of shipping.
        Is 10 thou enough off the foot ?
          No adjustment needed. My post was unclear in terms of it being an ad or not
          Lets attribute the whole thing to OCD (old codger disease)
          So nothing special or worth messing with
            Cue,
            Prolly a good motor for a medium lathe or mill but the price really doesnt sound very good. I recently got a shunt wound, 1 1/2hp, 180v off flea bay for $56 plus 20 or so frt..........
